Zum Hauptinhalt wechseln
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
26 Fragen Alle anzeigen
How to fix audio jack at the end of the cord?
The small mm jack at the end of my headset has come undone from the plastic seal around the wiring. So the green jack kind of just flops around. Now there is no sound coming to the headphones whenever it is plugged into an audio source. Is there any way to fix this?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Matt Thomas, yes there is . The green 3.5mm jack is your audio, so you obviously have some broken connection. Replace the jack the same way you would on a regular headset. Take a look at this guide to see how to replace an audio jack. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Matt Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 20,284
