Zum Hauptinhalt wechseln
Apple brachte das verschlankte und aufpolierte iPad Air am 1. November 2013 in den Versionen Space Grau und Silber auf den Markt. Es beinhaltet den A7 Prozessor und kann mit 16, 32, 64 oder 128 GB Speicherkapazität gewählt werden.
577 Fragen Alle anzeigen
My ipad air say ipad is disabled connect to itunes
my ipad is disabled how can i fix it
Ist dies eine gute Frage?
Bewertung 33
4 Kommentare
my pad is disabled ..how can i connect it to i tunes?
von
need a little more information such as how did it get locked? Incorrect password? etc
von
was new and grandkids set up stup and played with and cant remember anything so disabled
von
I forgot my pass word, tried to enter other pass words to many times.
von
Einen Kommentar hinzufügen
8 Antworten
Hilfreichste Antwort
First thing to rule out--time/date error from the battery going dead. Connect to WiFi--usually by going within range of a WiFi source that the iPad has connected to before so it will connect automatically. Hard reset to restart. (Power and home buttons for 10 seconds)
If not solved, then you'll have to erase the iPad and start over--all data will be lost. You can force the iPad to boot into recovery mode by doing a hard reset (as above) but this time leave the home button connected and the iPad connected via usb to the computer.
This will prompt iTunes to ask if you'd like to restore the iPad--i.e. erase and start over.
jessa
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
thank you so much, your answer is really helpful, it solved my problem too.
THANK YOU :)
von
Ipad locked up for no reason at all
Bewertung 2
1 Kommentar:
I forget 4 code .and lock
von
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to shut down. While pressing and holding the Home button, reconnect the USB cable to the device. The device should turn on
Bewertung 2
My iPad can't connect to iTunes ' how I can connect to my iTunes?
Bewertung 1
1 Kommentar:
How can I connect to my iTunes with my iPad?
von
I am deaf in computer ,
Bewertung 1
my ipad diabled to connect itunes
Bewertung 0
attention save this password in open ipad connect to itunes
Bewertung 0
Put the iPad Air into recovery mode and then connect to iTunes to restore it. Or consider a tool called Joyoshare iPasscode Unlocker to help you. These two methods are frequently used in terms of unlocking a disabled iOS device.
Bewertung 0
Antwort hinzufügen
Mabior wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 10,090
