Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Wifi and Rear Camera not woking after screen replacement
After replacing my screen on my iPhone 6 I noticed the rear camera would not load (also the flashlight does not work). So I took it back apart and took the camera off and then put it back on and now the wifi is not working either. I have tried hard resetting and resetting network settings. I am on iOS 8.1 and jailbroken if that helps.
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare:
Is the device registering panic.plist or panic.ips in the dianostics & usage menu?
von
no its not. but now the phone is randomly shutting off if i lock it and dont touch it for a few minutes. and it wont restart without doing a hard reset. any help would be greatly appreciated asap. Ive restored to the latest firmware and that didn't fix anything
von
Very carefully inspect the resistors around the battery connector for damage.
After Inspect resistors by the LCD, digitizer & sensor cable connectors, your looking to see if any were physically damaged by a tool while working. You may have to remove the black plastic static sticker to see visisble damage. let me know your results, take your time inspecting. Some of the resistors are so small they look like bits of dust. This way we can rule out any obvious damage.
von
theres no way i could've damaged it because each time i reconnected the battery it went right back in. Now one of the times i was putting everything back together I powered it one before putting on the retaining plate for the lcd and digitizer connectors, and there was lines running up and down the screen. So i tried to turn it off but it would not power down so I just disconnected the battery while it was still on. Could that have caused this problem?
von
Josh what would the blow resistors look like? Same problem, I'm down to solve the issue though have soldering skills
von
Einen Kommentar hinzufügen
4 Antworten
The phone 6 comes with a Wifi antenna which is connected to the logic board directly nestling up against the top plastic antenna stripe of the rear case. It will help the iPhone 6 to receive 3x faster WIFI. If the Wifi Antenna for iPhone 6 is broken, the WIFI signal will be weak or intermittent. you need the brand new iphone 6 wifi antenna
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
as povanila said, you need new iphone 6 wifi antenna
von
I have a device with exactly the same issue. Did you ever manage to fix the problem? Wi-Fi switch is grayed out on mine.
Bewertung 0
Damaged motherboard chips.
Bewertung 0
Hallo
I just replaced my iPhone 6 LCD then wifi and Bluetooth disabled ( gray ) iPhone still working normally
This issue damage in motherboard only or there is done other options
If you can advice how to repair it
Thanks
Bewertung 0
Antwort hinzufügen
AndrewHaskins1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 2,712
