Zum Hauptinhalt wechseln
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Fragen Alle anzeigen
How do I make sure hold switch is synced to logic board?
Hi there,
I have a 3rd generation iPod. While replacing the battery, I accidentally tore the ribbon connecting the headphone jack to the logic board. So I ordered a replacement headphone jack. I did the replacement, and at the bottom of the instructions, you wrote this: When reassembling your iPod, be sure that the plastic hold switch mechanism is synced with the hold switch on the logic board. The switch on the board is a small black nub that sits in the slot on the hold switch mechanism.
I can't figure out what you mean by making sure the plastic hold switch mechanism is synced with the hold switch on the logic board. I put the hold switch in the "locked" position, plugged in the ipod to turn it on, and it is still stuck in lock no matter what. How to I make sure it's synced?
Thanks!
Jess
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There’s a little black switch at the top of the logic board. Make sure that the hold switch on the outside of the iPod is in the same position as the little black switch inside.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
jessicabarnthouse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 87
