Zum Hauptinhalt wechseln
Ein Wecker, der den Sonnenaufgang simuliert. Er verfügt zusätzlich über ein Radio sowie eine USB-Verbindung und ist durch die Modellnummer HF3485 identifizierbar.
How to fix the light buttons that not always work properly?
I have a philips wake up light HF3470 and there are 3 buttons to control the light. (brigther, turn it on/off, dimm). Now 50% of the times these work properly. But sometimes when the on/off button is pressed, the light will dimm (as if the button below was pressed), and when the dimm button is pressed, the volume goes up (which is the button below it).
At first I suspected it to be a physical problem that the plastic of one button presses the other a little bit. But I dissassembled the light, and even when pressing the buttons without the white protectors, it still has the same behaviour.
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
I'm also having this issue. None of the buttons work at all. Anyone found a solution internally?
von
Had same problem.
After going through each of the PCBs it tured out that one of the button fas not working and disturbed the function of the others.
I just removed VOL DOWN and everything started to work (except vol down). Replaced it with a cheap one from ebay and now it's just as new!
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
If you opened it completely down to the boards level, then maybe you have noticed that the pushbuttons are no reparable. They must be changed with new. They are not expensive, but you need some skills for de-soldering the existing ones and re-solder the new replacement.
They look like:
http://www2.mouser.com/ProductDetail/TE-...
And the datasheet :
http://www.mouser.com/ds/2/418/NG_CD_157...
says that usually such pushbutton is good up to 1 million operations in normal conditions of temperature, humidity, assuming that is no overpressure or mechanical shock applied.
If you have the skills worth to try it given the fact that the lamp is not cheap, but be ready for surprises as: maybe the wires between pushbuttons board and main board to have some problems or even the integrated circuits on the main board.
War diese Antwort hilfreich?
Bewertung 1
Did somebody Change the Buttons like Victor suggested? Did it help? I habe the same problem. Cheap quality for such an extensive Item.
Bewertung 0
1 Kommentar:
I did not need to change the buttons. In my case one of the radio buttons had gotten stuck "depressed" internally. I simply disassembled the light (fairly straight forward), popped off the grey plastic button covers, and pressed the actual button beneath. I also applied some electrical contact cleaner to make sure it doesn't get stuck again. Has been working great ever since.
von
Tow of the buttons on my Wake up light are not working / got mixed up in their function: 1) Light up is only changing the clock upwards 2) select + button is selecting the menu, just like the menu instead of changing the clock (instead thats what the light button is doing). …I dismantled everything but can’t find out what is causing this mixed up buttons problem. (not an expert at all in electronics). Any suggestions on what to do?
Bewertung 0
I know everyone has likely moved on here but for anyone finding this issue today on the Phillips HF3470..
The buttons are a "right angle pcb mount tactile momentary micro switch" or something like that. 5mm spacing on the switch pins with PCB mounting pins behind at 7mm spacing. I found a 10 pack on ebay. Pacer PTA-116AJ. Made for Motorola. Hopefully these will fit and work better.
You can open of the clock, it's a real PITA to get all the clips to release to separate the bottom from the clock and get at the circuit boards. But it's not impossible esp if you don't care if the outer case gets marred up some.
On my wife's light, the light up/down buttons on the side were not working properly. There are more switches on the main circuit board but they are the same type.
The vertical buttons on the side are on one circuit board as part of a subassembly. The assembly has a wire/molex connector that goes and plugs into the main board with the clock display. Unplug that and this can be pretty easily taken apart to remove the circuit board. Theres some really small c clips on the pivot for the lever. Good luck not losing one when you pop it off. But can probably be substituted with some super glue or something. Rest of it comes apart straight forward after you peel a piece of plastic film off the side to gain access to two screws.
So.. here's the crux of the issue with the button controls on this unit. The micro switches don't each have their own circuit. They are all wired up to a main "loop" with different value resistors between each switch termination to the loop. So then the output from the board is the ground and "data". Each button completes the circuit but with a distinctly different resistance, and therefore voltage drop/or current at the "data" pin. A microcontroller interprets this value into the corresponding function. Sounds like a lovely, spacing saving, material saving design right? Yes, it's great when everything is working properly. The problem is when the switches start to wear out, they start adding some of their own resistance to the the circuit. This renders the function of the button inoperable, or can trigger a completely different function. If you press the switch just right before it's completely shot, the function works, but press it wrong and chaos! hah
Replacing these switches doesn't seem like too bad a proposition if you are an experienced in electronics soldering. The board doesn't have a ton going on. Just be careful not to damage any pads or desolder any of the resistors. If those one comes loose the whole thing is toast unless you can get it replaced. They are VERY tiny. I have yet to try and fix this lamp, the switches are on order. I was thinking of desoldering using a heat gun but I think a wick is a better way to go here with the resistors at risk.
I'll update this after my attempt. If anyone needs pictures let me know and I'll upload some.
Bewertung 0
4 Kommentare:
@dhotaling Did you ever end up fixing it?
von
Yes I did and it works perfectly again. Recommend using a solder sucker to unsolder the switches. The hardest part is the disassembly/assembly of the whole unit. Not the soldering if you have any experience with that. Good luck!
von
Thanks for posting about this. I have this clock/wake up light and the “menu” and “select” buttons on the front have started acting like they are the arrow up and arrow down keys, respectively. The menu button will occasionally perform correctly, but the select button never will, rendering it impossible to set the time, alarm, or other functions. I wish I had experience with electronics soldering, because I haven’t been able to find a wake up light that I like as well as this one! I guess I could look for a tutorial on YouTube, but it’s daunting. Any recommendations for how to learn?
von
Wondering if this is designed to wear down at some point (or require a soldering intervention) because like Mary back in November I'm having the "menu" and "select" buttons on the front acting weird. Even worse, I've got the light blasting on at random times, including in the middle of the night. There was definitely no alarm set for 4:26am but the light went on last night at 100%, and none of the light buttons worked to turn it off. I had to unplug the lamp entirely and set a phone alarm. I hate the idea of giving up on a semi-functioning appliance but I can't have my sleep interrupted.
von
Antwort hinzufügen
Peter Ronsmans wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 29
Letzte 30 Tage: 127
Insgesamt: 8,419
