Zum Hauptinhalt wechseln
Reparaturanleitungen für Computer-Tastaturen, die nicht von Apple sind.
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
War diese Antwort hilfreich?
Bewertung 1
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
Bewertung 1
Bought a new keyboard after mi puts roba
Bewertung 0
it broke off during normal use plus the wand has stopped working
Bewertung 0
1 Kommentar:
were do i buy new keyboard and wand
von
Antwort hinzufügen
Lucas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 5,253
