Zum Hauptinhalt wechseln
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
55 Fragen Alle anzeigen
Frage geschlossen
Can I replace touch panel with glass?
Well, sadly I've dropped my lumia 1520. After the fall touch panel doesn't work as well as glass is fully destroyed.Lcd screen works just fine. Can I actually replace only my touch screen with glass, or I should buy the whole module instead?It is pretty expensive.If i should buy the whole module where can I buy it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You can replace the glass only, but it requires professional tools and skills as it's pretty difficult and risky. Usually it's not recommanded. While replace the whole unit is much easier, even the official tutorial guide suggests so. Here is the disassembly and reassembly guide from Nokia: http://ifixit-documents.s3.amazonaws.com... and here is the screen unit for reference, http://goo.gl/F19g0e hope it helps.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thanks a lot for your answer.But can it actually be that digitizer isn't broken?If it is some contact problem does it mean that I can replace only the glass?And can I buy the whole module from china or is it too risky?Again thank u for your help.
von
Hey Sayar, if your LCD still displays well, then you can replace the digitizer only. But as I've mentioned above, it requires professional tools like: LCD separater, molybdenum wire, LOCA etc. You can search on Youtube to learn what others do to replace the glass only. As for the parts from China, my local repair shop recommends this store (apparently they buy all their parts from them). I've bought from them a few times, and have never had any problems, so I think if you buy from well known and respected shops you shouldn't have anything to worry about.
von
I suggest the cell phone parts supermarket, http://goo.gl/LJUaOZ, they works with its customers to make them happy. unlike other wholesale company, they don't require min quantity, i get my replacement parts by free shipping, this company will be my first choice vendor for any product that they offer.
Bewertung 0
Hello.
First sorry for my english...
I want to buy original lcd and searching i found this post.
The user Mandy link this original lcd: http://goo.gl/F19g0e
My question is about the blue piece near headphone. What it is?
Bewertung 0
1 Kommentar:
That's one part of touchscreen, which is not covered by the frame, and what you seen is blue from outside.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,099
