Do sounds seem reversed while using the headset?
When sound sources that should be coming from the left or right come from the opposite side of your headset.
Ist dies eine gute Frage?
Hi Sam,
You may have a 'reversed' connection in either the headset cable or the headset itself.
If you have an Ohmmeter you can test this out. Test from the 'tip' of the cable plug at one end to the 'tip' of the cable plug at the other. There should be continuity. By convention the 'tip' is the left speaker.
The next connection on the plug down from the tip is known as the 'ring' and it is used for the right speaker.
If you get a connection from the tip at one end to the ring at the other your cable is reversed.
If your cable tests OK it may be that the wires in the headset itself are reversed.
Either way I suggest that you contact the manufacturer as obviously it is a production fault, as I assume that the headset cannot be worn or altered to suit.
The image shows typical connections. Usually it is only the microphone connection that may vary, unless the manufacturer wishes to have a 'proprietary' connection setup which forces you to purchase their product, (until you work out the connections yourself , of course).
War diese Antwort hilfreich?
its basically pretty easy. i had this problem but i solved it in few seconds.
basically you have the magnetic cover of the astro headset. First you need to remove ur microphone then u need to switch the outside magnetic cover ( the one with the microphone hole in it. Just switch those over and ur good to go. ull notice that the astro has 2 microphone hole on both sides. and voila problem solved. Hope I could help !! cheers
Is there a video that shows you how to do it?
It was exactly the problem. Awesome. Thank you
Make sure your headset is on correctly. Your left ear should be listening to the speaker labeled with 'L'.
I have the same issue please help!
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 21,712
1 Kommentar
I have the same problem someone please help asap.
von Sam Nelson
