Zum Hauptinhalt wechseln
Inspiron 14z, a 14-incher with a slimmed-down aluminum body, available in a surprisingly staid color palette. For 2012, Dell had updated the 14-inch Inspiron 14z with Intel's 3rd Generation Core Series processor and a brand new design that's thin and light enough to make the system an Ultrabook.
Horisontal screen lines and screen freezing.
The screen has small, white lines across the top and from time to time the screen freezes, I have found a remedy to this but it does not really work. I adjust the angle of the screen, this only fixes the freezing screen though.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Cillian, if adjusting the angle of the screen fixes the issues with lines going through the LCD, you could have issues with the display cable. The freezing of the screen could be a memory issue as well as a GPU issue. Try an external monitor and see what you get. If that works, you will have to take your laptop apart and take a look at the cable and connector. I would also recommend to change the thermal paste on the GPU/CPU etc.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Cillian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,408
