wi-fi is not working. how to repair it?
wi-fi is not working. how to repair it ?
Ist dies eine gute Frage?
First of all tell me if issue is the same booting your xperia in safe mode
Turn off the device.
Press and hold down the power key until the phone vibrates.
Wait until the Xperia™ logotype disappears.
Press and hold the volume down key. The device then restarts in safe mode.
To exit safe mode, restart the device.
So if your phone works fine in safe mode probably issue is caused by
- a conflict with a third party app that you installed after purchase
- firmware corrupted
So first of all you can remove all recent third party apps and if issue persists make a factory reset.
Remember that with reset you will loose all your datas.
for more information, https://talk.sonymobile.com/t5/Xperia-L/...
War diese Antwort hilfreich?
I did all above steps and still the issue persists, I also tried by repair software option through PC companion.
the phone has wifi problem that is activated each time the phone is turned off and turned on automatically
did you get solution
the same problem is happening with me please tell any solution
this problem not solving with software repair, this killing me. Please solve it
Even I'm facing the same issue. when I switch on wifi..... Phone hangs and start keep on rebooting.
When I visited Sony service , they said it's the motherboard compliant.
This is what I got answer from Sony service center.
Bloody Chinese Mother f-ckers.
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 7,804
