Zum Hauptinhalt wechseln
Ein tragbarer E-Reader, der von Amazon entwickelt wurde. Die Reparatur ist unkompliziert und erfordert nur Hebelwerkzeuge und Schraubendreher.
Can the USB socket be replaced without replacing the motherboard?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 7
2 Kommentare
This is for the kindle paperwhite.
von
I can’t recharge the battery .The yellowflashes intermittentantly as I wobble the recharging cord seemingly there is a connection problem.
What do I have to do to restore the charging capacity.?
Have tried several recharger cords.
Your advice would be welcome.
Thankyou
Mairin Campbell
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The USB socket is soldered to the motherboard, so it can not be easily replaced without replacing the motherboard. In theory the socket could be replaced with some careful soldering work if you could get your hands on a replacement socket. For someone experienced with replacing small components on circuit boards I'm sure it would be possible, but if you are a beginner with this sort of thing you may do more damage to the circuit board by overheating it. Look closely at the photos in this guide before deciding to try this repair.
War diese Antwort hilfreich?
Bewertung 8
Antwort hinzufügen
Tom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 28
Insgesamt: 2,144
