Zum Hauptinhalt wechseln
1.6 oder 1.8 GHz Dual-Core Prozessor, 2 GB oder 4 GB SDRAM, 64 GB oder 128 GB SSD
I like to know how to turn on my MacBook air without keyboard
hello I am very proud of this website I looked everywhere I have not found I like to know how to turn on my macbook air model A1370 mid 2011 without keyboard
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
You are looking for the power pads on the A1370?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
men, use the power on pads. Bridging those two pads should power on your MBA unless there are other issues with it.
War diese Antwort hilfreich?
Bewertung 9
1 Kommentar:
This was super helpful. Thank you ❤️
von
Hey men
What is probably the easiest way to do this, would really be just to remove the MacBook’s battery. If the battery isn’t present the power button becomes disabled because your power runs from the charging brick the MacBook came with. So if you connect the MagSafe connector, the Mac turns on instantly. If you disconnect it the MacBook kills because there is no power.
Hope this helps!!
Bewertung 2
Antwort hinzufügen
men wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 2,120
