Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
This is most likely due to a broken impeller, and the impeller assembly will need to be replaced. It could also be due to air locked in the pump housing, which is most likely due to the pump not be fully submersed.
