Zum Hauptinhalt wechseln
The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
29 Fragen Alle anzeigen
Why does my Roomba vacuum makes a ticking noise while its charging?
I charge my Roomba Pet Series vacuum cleaner nightly. Just a couple nights ago it started making a ticking noise while it charges. Its not very loud, but I am wondering if it is harmful to the robot, or if it could have potential danger.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
We made sure our Robot was making contacts, cleaned contacts, tried different electrical outlets, pulled out dust tray. One holds a short charge, and my second Roomba doesnt charge at all!!. So my question is why should I purchase both battery and charger , and this may not be the problem, And why cant the company give us a straight answer!? Thank you
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
This is a fairly common issue with the iRobot vacuum cleaners. You may try plugging the charger into a different outlet. If the noise does not bother you, don't worry about it, it is not harmful to the robot.
If you feel the need to stop the noise contact iRobot customer support.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I have the same problem, but it doesn't charge.
von
For anyone finding this via Google like me:
Got told by a tech support rep to pull the dust bin slightly out of the Roomba while it charges. That seems to have solved the issue.
Bewertung 2
1 Kommentar:
My Roomba model 865 is brand new and started the click noise while charging at the first day.
"told by a tech support rep to pull the dust bin slightly out of the Roomba while it charges." this is just a work arouns not a fix.
von
There is an issue with Roombas where the battery won't re-charge if the battery level gets too low. You have to buy a separate external battery charger, available on eBay, Amazon, etc. Google “external battery charger”.
Once you charge it in that, it will work in the Roomba again. I’ve had to do that with mine a few times.
Bewertung 1
I have a Roomba 880 and it clicks (electrical) thru the speaker. Tech support said new Roomba with a discounted price. I just disconnected the speaker and it works great. No clicking or any sounds. Good or bad it still works.
Bewertung 0
My Roomba 655 series stopped working.
Googled for solutions. Replaced with new battery as recommended.
All lights came on when I put it for charging. After a few hours, checked and found that the lights are off. Roomba still doesn’t work.
Now it makes a ticking sound when put on charge. Sound continues even after pulling out the dust bin and changing the charging plug to a different wall socket as recommended above.
All contacts are clean. Tried with the dust bin pulled up.
Also tried the hard reset by pressing the Spot, Clean and Dock buttons simultaneously.
The only thing I have not tried is buying an external charger to charge the new battery.
Bewertung 0
1 Kommentar:
I am having the same issue.
von
More reasons a Roomba can make these sounds are...
  1. Voltage spikes are sent to the dustbin making it make a slight tick.
  2. A software\hardware issue making the speaker make a tick sound
  3. Faulty charger.
Bewertung 0
Antwort hinzufügen
Rhett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 51
Letzte 30 Tage: 172
Insgesamt: 29,770
