Zum Hauptinhalt wechseln
Modell A1418 / Ende 2013 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
247 Fragen Alle anzeigen
hard disk retainer and brackets and sata and power cord
iMac 21.5 inch late 2013
Hello Folks
I bought an imac late 2013 which has a 21.5 inch screen with 256 gb SSD installed. As much as i know this ssd id pcie so there is a free sata slot inside which i can install another ssd or hard drive in 2.5 inch form. I watched the videos and i know that i can install the harddrive as long as the sata and power cables are plugged in to the logic board. Because my configuration is SSD only i wonder if apple placed the sata and power cords plugged in ? Because if they arent plugged in i will have to tear down the system further more which i dont want to do...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Well it depends on if the SSD is mSATA card which is installed on the back of the logic board or a straight SSD drive installed in the normal hard drive slot. If it is the card in back there should be little problem installing a normal hard drive. Just get the adhesive strip kit to remount the screen.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Well the ssd is connected on the back of the logic board so it is msata..
so i wonder if the power cord and sata cord are missing in my mac and i have to buy and plug them too ? and the mounting brackets are missin as well ??
cheers
von
Antwort hinzufügen
ozciceky wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 337
