Zum Hauptinhalt wechseln
Repair and troubleshooting help for the Memo Pad ME172V, a 2013 tablet manufactured by Asus.
16 Fragen Alle anzeigen
stuck no usb cable connected
help...my memopad me172v stuck "no usb cable connected" i try all trick ..but not working....
1.sd card 4gb (fat32-cleandata.zip)
2.rkandroid
3.easyflasher
please help
screen shot - connect my computer
unplug my computer
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Before doing a factory reset open the tablet and disconnect the battery for a few minutes and while the batteries disconnected hold the power button down to remove any static discharge in the memory. If theres no joy after that then do the reset but remember you will lose all your data and apps . this reset you to factorey like it was when you first got it. This video shows how to open the back and disconnect the battery .you dont need to remove the battery just disconnect it.
https://www.youtube.com/watch?v=lcKIPddf...
Hope this helps
War diese Antwort hilfreich?
Bewertung 3
you need to reset it .. HARD RESET or just continue to root you tablet
you need to download some root kits (find it on google) and turn on you tablet like Volume Up + Power button
and follow the instructions
Bewertung 2
1 Kommentar:
Thank you ujojedobry, great advice. worked for me!
von
My Asus tablet stuck on no USB connected how to fix it
Bewertung 0
Antwort hinzufügen
zeckleus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 10,987
