Upgrade trackpad to multiPod Touch possible?
Hello!
My MBP has only two-finger scrolling, and I understand the newer trackpads have additional hardware to support multiPod Touch. Would it be possible to swap my trackpad with the new unibody one to enable multiPod Touch?
I was looking at this part in particular:
MacBook Unibody (A1342) Trackpad
Thanks!
Krishna
Ist dies eine gute Frage?
3 Kommentare
Thanks to both you for taking the time to respond. :)
The kext workaround won't work in my situation since I'm on a Santa Rosa MBP; I think Penyrn top-case swap would be the way to go. I'll check it out!
--Krishna
von krimb1
Kevin, your suggestion worked great!! I got a Penyrn topcase off eBay and did the cable swap like you suggested; worked like a charm. FWIW, my fn keys are all different even though I swapped in my old keyboard; it's interesting that's programmed into the topcase! Many thanks again. --Krishna
von krimb1
You're welcome Krishna, and I was aware of the fn button situation. There are various places you can get the F1-F12 key caps online, or if you can find a water damaged Penryn obviously the plastic keys will be OK. Glad my research was able to help you!
von kevinweber
