Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
What are some solutions if restored the computer before replacing the
After restoring the whole computer and deleting everything on it, as I was about to reinstall Os X Mavericks again, the hard drive would not appear. It is because before in disk utility it said that the s.m.a.r.t. status is failing. If I replace the old hard drive with a new one, how do I format it so that I will be able to install Os x Mavericks and startup my laptop brand new again?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
https://www.youtube.com/watch?v=0K82njig...
I found the steps just in case anybody else has the same question ^
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Internet recovery is great if you have a good and fast connection. Sadly, most people don't. It also can be expensive if you are using your cellphone hotspot function. Lastly, not all of the Mac's have the ability to use this service even with the newer OS's (older models).
This is were being prepared ahead of time can save you time & money! At home I've already created a bootable USB thumb drive which also holds the OS installers as I upgrade the OS on my systems. That way I don't waste time trying to rebuild my system or even to maintain it (running Disk Utility and HD defrag tools as needed)
If you have a friend who has a Mac you should be able to setup a USB thumb drive as a bootable drive using Disk Utility & OS Installer already on his system. Once the USB thumb drive is prepped, you should be able to copy over the OS installer app onto the USB thumb drive to boot up your system so you can prep and re-install the OS once you use it to boot up your system.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
This might be a dumb question, but would an external hard drive work instead of a thumb drive?
von
Yes! it is just as good! The issue is mostly cost and size. Thumb drives are cheap and you can have a bunch setup with different OS's and tools. If you can get a Thunderbolt Hard Drive (or for older models FireWire) as the I/O speed is much faster than USB port these systems have. That way you're not twiddling your thumbs as you wait for the OS to load ;-}
von
Antwort hinzufügen
milushik411 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 75
