Zum Hauptinhalt wechseln
upgrading battery from 2800 mamp to 3200 mamp
is i can upgrade a battery with more power for my tab ?
Ex: 2800mamp to 3200 mamp ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Mohammed Buhari sure you could if you can find one that fits your XTouch. Be aware of the scam with higher capacity batteries etc. Most of those are not any better than the standard batteries. You can try and search for a better battery based on the physical size of yours as well as the connector. Check reputable sellers only. Check this The myth of the "high capacity" batteries since it is still true today. Remember, higher capacity batteries also take longer to charge
War diese Antwort hilfreich?
Bewertung 1
Now Why? How do you upgrade a Battery’s MAH
IS A BAD IDEA TO DO IT!
Bewertung 0
Antwort hinzufügen
Mohammed Buhari wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 151
