Zum Hauptinhalt wechseln
Manufactured in January 2013. Possesses full HD quality recordings with a 72x zoom.
9 Fragen Alle anzeigen
Why is my battery life so short?
Dear iFixit helpers,
I recently purchased a Panasonic HC-V110 for myself and I love everything about it, but I have noticed that the battery life is very short. I'm not sure why this is considering I bought it only two months ago and it hasn't sustained any type of damage whatsoever.
Do I have a defective battery and need to purchase a new one or am I able to fix this problem?
Thanks!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hey there!
There are two possibilities that I know of for this issue. The first is the temperature of environment. In colder temperatures, the device loses the ability to maintain power. Be sure to keep the device in a room temperature environment to ensure longest possible power life. Are you in a cold enviroment while using the device? The other is that the battery life time is limited. The battery only has a limited amount of life within it. Therefore, if the battery is fully charged and will still not sustain the charge then the battery is most likely worn out and requires replacement.
Hope this helps! :)
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jenna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 290
