Zum Hauptinhalt wechseln
Anleitungen und Hilfe für verschiedene TV-Gerätehersteller und -typen.
9064 Fragen Alle anzeigen
How to replace broken screen on Toshiba smart TV?
The Screen is cracked the screen will show a picture on each side but in the middle of the screen it is black, I want to fix it my self but how do I get parts and a guide to repair.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare
I call Toshiba and they said it was repairable, I check with a repair service and he said it cost more than the TV I paid over $800. for a 52 inch I need to order a screen for it any help out their .
von
Hi sis I have the same problem do u manage to find the replacement LCD screen? If yes can I know whr to find pls.thank u
von
Unfortunately the cost for new LCD is going to be high, and most suppliers will not ship screens as they are almost always going to end up broken in shipping, they are very fragile. Given TV costs have dropped tremendously over past couple years, it makes replacing screen hardly worth it given you can buy a comparable new 55 inch smart TV for under $350. last I looked. Having replaced and removed screens several times, it is a very difficult thing to do without breaking screen, even for experienced technicians.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Joyce Mcvay,
Well, I guess Toshiba gave you a correct answer, it is repairable, BUT, price will be high (and could even be higher then a new TV).
This is what I would do:
Try to open the TV, look for the LCD model number on the back of the LCD. Then, search the internet to find a replacement. Maybe you'll get lucky.
Other option is: go searching for a "same model" TV with other malfunctions and exchange the good LCD into your TV.
By the way, what happend to your LCD?? Howcome it is broken?
Greetz, Pierre.
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
Thanks Pierre. My TV got broken because my 11 year old twins boys was play ball in the den and the ball hit my coffee table and a bowl sitting their and the ball hit the bowel and bowel hit the TV screen and I had jut gotten it, still had a few payment to go. Yes I'm sick but that kids , thank again for the info.
von
Hi Joyce Mcvay, that's too bad, but accidents happen. I hope you can find a spare part or TV to repair your lcd. Goodluck.
von
Also try open the back of TV to find unique part number as part numbers are important then just TV model. There could be many similar models and each of them with different facilities to use on screen.
As not all LCD parts are axactly made from same brand .
von
My wife threw the remote a the screen of a toshiba plasma tv it Doesn’t appear to be cracked it has vertical lines on right side in multiple colors is there anything I can do to fix it
von
My 55 in fire tv has a broken panel can I get any parts or panel where do I get any parts.
von
1 weiteren Kommentar anzeigen
Hi im need toshiba 55u2963dbt screen
Bewertung 0
2 Kommentare:
Hi how do I get in my fire tv service menu I want to flip the screen
von
My toshiba smart tv screen 42 inch is broken I need service please
von
Antwort hinzufügen
Joyce Mcvay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 46
Letzte 30 Tage: 172
Insgesamt: 27,900
