Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Where can I find heat sink for the A8 processor?
Hi,
My iPhone 6 got fixed few months ago (charging unit damaged, no warranty for iPhone in Israel since it bought from US). Suddenly I felt the battery was "free to move" inside, so I opened it and sticked it with adhesive.
The thing is, while I opened the iPhone I found out that when they fixed my phone - they didn't put back 2 parts. I found where to buy one of them but I couldn't find where to buy the other one, which is the metal (I guess it is called "heat sink") which sits on the A8 chip...
Does anyone here know where can I find it? Otherwise - have any idea for other solution? (Talking with those who repaired my iPhone won't help since too much time was passed...)
Thanks for the help in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Bro i know im extra late, but the pices could be found on amazon, do your own repairs from now on its simple, also, its probably the shielding apple doesnt use “heat sinks” like other cellphones, im actually looking into why they dont and everyone says “no phone uses it” but every andrioid flagship like the s7 s8 and note 8 op5T etc use a copper coil as a heat sink while iphones have never done this, some claiming the aluminum acts like a heat sink, given, again its probably the shielding and you can get a fill replacement for the homebutton screen etc (all the brakets and shielding) on ebay for around $7 (for thr iphone 7 in a matte black) i hope you had luck....
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Actually, the shield over the CPU also acts as a heatsink. When you first remove it, it is filled with a carbon based heat sink compound to allow good thermal conductivity with the shield.
von
Thanks bro,
It is late (my iPhone 6 got other issues since then and now it's not in use) - but for the other's which might have the same question it indeed can help.
Bewertung 0
Antwort hinzufügen
niralshek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 683
