Zum Hauptinhalt wechseln
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
Bewertung 3
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
Bewertung 0
1 Kommentar:
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
von
Antwort hinzufügen
Ron Skelly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 5,022
