Zum Hauptinhalt wechseln
Als preisgünstiges Smartphone 2013 veröffentlicht. Das Idol verfügt über ein 4,7 Zoll IPS LCD Panel, einen 1 Ghz dual-core Prozessor und eine 8 MP Kamera.
35 Fragen Alle anzeigen
How can I fix a broken and unresponsive screen?
I recently dropped my phone on a gravel pathway. The screen is broken and cracked and the screen is unresponsive. How can I fix it and what do I need to buy in order to replace the broken parts?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 23
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Hello Aimee, there may be a few options depending on the displays condition.
Touch screens consist of a few different parts that can be replaced depending on the problem a user encounters. The two main parts are referred to as the digitizer and the LCD. The digitizer is the part that is responsible for sensing touch and sits in front of the LCD and is adhered to the bottom side of the top sheet of glass on the screen. The LCD is only responsible for displaying the image on the screen.
So if your screen is cracked and the touch function is not working at all or incorrectly but the it does display an image fine than you have the option of only replacing the digitizer. If the phone does not display a picture, or if the picture is distorted or displayed incorrectly than the LCD has been damaged and needs replaced.
You can usually purchase the display parts in numerous forms such as from individual pieces to the whole display assembly. Sometimes you can buy the front housing with the display already adhered in place. It all depends on the damage and how easy you want the repair to be and how much money to spend. Replacing the whole display unit as one is usually easier than replacing single parts of the display, but of course costs more. Hope this information is helpful to you.
War diese Antwort hilfreich?
Bewertung 10
5 Kommentare:
Thank you so much! This was very helpful :) The screen is fine nothing looks distorted so i think i'll just have to replace the digitizer.
von
Did it work?
von
Wow!!! Amazing
von
Im confused!
von
Start your own question and you'll get specific help for your problem
von
the same problem I am facing, my phone touch screen not working. Now the question is how to transfer my all data from not working phone to any other source. ( no memory card only internal storage) Ian Roussel
Bewertung 1
My iPhone 6 cracked and is unresponsive, I can only switch it off and press the home button
If I put another screen on will it solve my problem?
Bewertung 0
1 Kommentar:
i'm having the same exact problem.
von
No. If the screen doesn’t respond anywhere you’ll probably need deeper repair, but because it is an iPhone it is advisable that you replace it entirely or upgrade. Replacing the screen isn’t likely to work if it isn’t responding at all, and paying for a repair is risky because with Apple smartphones they tend to have a high failure rate. Basically you’d most likely save more money by buying a new device or upgrading to a better device, instead of paying for a repair that could fail.
Bewertung 0
help me please my tablet screen wont move
Bewertung 0
Antwort hinzufügen
Aimee Luong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 69
Letzte 30 Tage: 290
Insgesamt: 127,102
