Zum Hauptinhalt wechseln
Repair and disassembly guides for Acer Iconia Tab tablets.
361 Fragen Alle anzeigen
How to fix shutdown of an acer iconia B1-730?
My acer iconia 7 B1-730 would not charge and turn on at all after randomly shutting down when its battery was at around 50%. Don't know why either the charger or the device itself, but still it won't turn on, is there anyway of fixing this?
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You can go through the easy steps first, try a different cord, try a different brick. Most likely though your issue lies with the battery or the board. You can order a battery online if you are confident enough to change it out yourself, but if it's a board issue you'd be better off getting a new tablet rather than spending the money to fix that one.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Christian Balon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,787
