Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
256 Fragen Alle anzeigen
What is this component and how do I remove it?
I have Samsung Note 4 that has water related damage, which has resulted in distorted audio from the loudspeaker, the ear speaker and headphones. I used the very help full guides from iFixit and disassembled the phone and cleaned off all the corrosion that I can see. (There was quite a bit) My sound problem may have gotten a little better after my cleaning, but it definitely isn't fixed.
I found this diagram <http://www.techinsights.com/uploadedImag...> that shows the audio amplifier in this location. But it appears to be protect and covered by a cage.
What is this covering called? Can it be simply soldered off?
UPDATE:
I was about to solder it off and then I realized it pops off. I still don't understand its purpose. Maybe electrical shielding or physical protection?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Shawn Murphy those are EM shields. They protect your cellphone from interference from its own EM fields
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Shawn Murphy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 621
