Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Ist dies eine gute Frage?
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 1,671
4 Kommentare
Is the mower turning over at all or is it just a dead mower?
von Nathan Wells
turning over backfires thru carb
von allenperkins364
adjusted air gap valves set gap on coil
von allenperkins364
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
von meriview@aol.com
