Zum Hauptinhalt wechseln
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
black screen and 4 beeps
No picture want start, black screen and 4 beeps
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Kissah Davis, 4 beeps on your Dell are for a Memory read / write failure. This could be caused by a bad memory module. First you should try to reseat it. To do that you fully open the securing clips, align the notch on the bottom of the module with the crossbar in the connector, place several fingers on top of the module and firmly push the module down into the slot, until the module snaps into position. If the module is inserted correctly, the securing clips will snap into the cutouts at each end of the module.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
After I'v done the laptop still has black screen BUT no beeps
von
check screen.....press d and power button
Bewertung 0
that sounds like a power supply unit problem get a can of blow-out and blow it out real good.
Bewertung 0
Antwort hinzufügen
Kissah Davis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 8,040
