Zum Hauptinhalt wechseln
Pavilion dv1000, Intel Pentium M 1.5GHz, 512MB RAM, 80GB hard drive
20 Fragen Alle anzeigen
Frage geschlossen
MSProject - error opening exported XML file
I exported a large (4,000 tasks) mpp to xml and when I attempt to open it with Project I get the error "An unexpected error occurred... The file may be damaged." I tried exporting it several times but get the same error each time. I don't see anything obvious in the xml, but it is huge and something could be lurking someplace that's not apparent. Does anybody have any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Re-create a whole new file from the corrupted/bloated file:
1. Open a new blank project file
2. Go to Insert/Project and insert the problem file.
3. Select the first task which will be the insertion point summary line.
4. Go to Project/Task Information/Advanced tab.
5. Uncheck the "Link to Project" button and hit "OK".
6. If the file isn't already expanded, expand it.
7. Select all tasks below the top level summary line.
8. Out dent the selected tasks.
9. Delete the first task which previously was a summary line.
10. Save the resulting file.
One more resource might be effective for handling your problem...
https://social.msdn.microsoft.com/Forums...
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 163
