Zum Hauptinhalt wechseln
Repair guides and support for Kenmore washing machines.
1859 Fragen Alle anzeigen
Why is there grey powder on the floor is front of washer?
Why is a grey gritty powder on the floor in center front of my machine (kenmore front load washing machine 40272900). It feels a bit like concrete dust. It seems to happen if the spin cycle becomes loud.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There are concrete counterweights in the front of the machine. We had a Kenmore front loader, and one weight broke in half. The raw edges rubbed and made the powder. After a while a loud banging was heard at the weights became loose enough to bang against the front panel. These can be replaced-in our case I used liquid nails adhesive to stick the weights together (I also drilled into each halve, and put a threaded rod in place as a splint).
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
There were loose chunks of concrete in mine. The washer occasionally leaked. Service calls did not find anything until the knocking stated. It also doesn't leak anymore either.
von
Antwort hinzufügen
Rita Moore wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 3,310
