Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
Frage geschlossen
Half of Keyboard not working after water spill
I have a MacBook (late 2009, I believe) model# A1342. After a small water spill, a portion of the keyboard stopped working. I'd say about half the keys do nothing, and it behaves as though the Shift key is constantly pressed. Everything else about the system works perfectly, and I can still use it if I plug in an external USB mouse & keyboard.
I am guessing the only option for repair is to replace the keyboard, but I wanted to find out for sure before I go ahead and do that. Are there any other components that could have been damaged to cause this issue?
If I do have to replace the keyboard, what part do I need and is there a good guide on how to do it somewhere?
Any help at all will be much appreciated!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The A1342 macbook keyboard can be replaced but it's a difficult job if you compare with the macbook pro keyboard replacement. The A1342 top case access to the keyboard is blocked by a black panel glued with resin (not easy to separate). There are no screws to retain the keyboard to the upper case but plastic melted spots so you have to heat the plastic spots to remove the keyboard and reheat these spots to reinstall the keyboard. Also unlike the MBP A1278 keyboard, the A1342 keyboard is hard to find especially the QWERTY french-canadian keyboard that has the same form factor that the AZERTY keyboard from FRANCE. If you have the France keyboard, the US keyboard wont fit in your top case, form factor is different (return key)
For all theses reasons I think it's a better decision to buy a good working used top case instead of trying to replace a faulty keyboard in the A1342 macbook model.
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
Thanks, I forgot about that board.
von
Oh wow, okay thank you for the info! It's starting to look like this machine will be scrapped for parts.
von
That uppercase can be had used for under $75: http://www.amazon.com/gp/offer-listing/B...
von
Even if the Macbook comes from France you can transfert all the components in a US top case. The only difference between the two machines is the keyboard. The A1342 is still a nice machine. I'd replace the top case and sell it.
von
Once these keyboards get shorted out, it would take someone like louis Rossman to repair them and the time and effort just aren't worth it. To see if it's just the keyboard that needs replacing plug in an external keyboard and mouse and see if everything works.
Bewertung 2
6 Kommentare:
External keyboard works just fine. So would that mean it needs an Upper Body replacement? Yikes, that's a pricey repair for a 5 year old computer.
von
No, you can replace just the keyboard and save a whole lot of bucks. It is labor intensive. You have to remove about 67 tiny screws and put them back in. I use an electric screwdriver to get them out. The keyboards can be found on eBay or out of Shenzhen. Email Jack Yang at sales2@advanced-mark.com. I don't know if he will sell such a single small part but tell him I sent you. My order last week took 4 days to get.
von
Copy this address quickly as it's another parts supplier and iFixit may be offended so I will remove the answer shortly. The repair takes me about 1 1/2 hrs.
von
Thank you very much! I will look into that option.
von
One more question, if you don't mind. The laptop in question was originally from France, and has a French keyboard. If I replaced it with a US/Canadian keyboard would it work/fit properly, or do I need to track down a French one?
von
1 weiteren Kommentar anzeigen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 870
