Zum Hauptinhalt wechseln
Das Gerät wurde in 2014 veröffentlicht und hat einen 11,6 Zoll Bildschirm. Das Gerät ist ein 2-in-1 Convertible und hat einen Touchscreen.
How to fix a crack screen
how to fix a crack a crack screen
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
without knowing the exact model and size of the screen it makes it a bit more difficult to give a better answer.
You will need to find a replacement screen, for it is pretty well impossible to fix a cracked LCD screen.
However, there are lots of youtube videos explaining how to dismantle a notebook screen to replace it with another good one.
It should be not too difficult to find a replacement part on ebay, or other places on the net. If you go to HP and search for your exact model notebook, you should be able to download the service manual for your notebook, which will have replacement part numbers for each part of the notebook. Use this part number to find a replacement LCD screen by searching the net with that part number.
Sometimes you need to first remove the screen from the lid housing, to find out how many pins the connector that connects the LCD to the motherboard has. And if you can not find a service manual, then when you have removed the LCD screen, there will be part numbers on a sticky label on the back of the screen where the above mentioned plug is, which you can use to find the correct replacement.
Some models you can remove the screen without having to dismantle the body of the notebook. You can un-clip the thin plastic housing frame that sits around the screen's edge, then unscrew the screws that are revealed when that is removed, which hold the screen to the lid.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Latoya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 38
Insgesamt: 4,992
