Zum Hauptinhalt wechseln
Modell A1051 / 4 oder 6 GB Festplatte
Why doesn't my click wheel work after I changed the battery?
The new battery charged up fine and the display is fine, but nothing happens when I push the click wheel. When I reassembled after putting in the new battery, it did not seem as if the orange click wheel ribbon stuck back onto the logic board; I hoped the metal bracket would hold it down in the right way, but apparently not. Is this fixable? Thanks!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Sounds like you did not properly seat the connector back into the board. I would take it apart once again and make sure you properly seat the click wheel connector in it.s socket before attempting to close. just hope you didn't damage the connector on either end when you closed it without properly seating it. Use this guide here
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
+ Ralph
von
Like Majesty said, you most likely did not seat the connector properly back in place. If it is seated properly, however, then you may have damaged the connector or ribbon cable when working on the unit.
Bewertung 0
I would recommend looking for damage in the cable or a lose connection like others said, however, sometimes when reinstalling the board, if it scrapes to much against the metal shell, it can cause a chip to break or fall out. There’s one chip that, if broken, will make the click wheel cease to work however the rest of the ipod would work fine. and lastly, I’m surprised no one so far has recommended taking off the top bezel and making sure the lock switch is in the right position, as that could be the problem and would be a very simple fix.
Bewertung 0
Antwort hinzufügen
ekeeling wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 44
Insgesamt: 4,374
