Zum Hauptinhalt wechseln
The Dell Latitude E4200 is a portable device manufactured in 2008.
8 Fragen Alle anzeigen
How to fix Bios Password problem?
hi guys I have a problem with my PC it requires a bios password when I boot it up, so I have no password for that, all the tricks didn't work with me help me out please, by the way I bought it with this problem thanks in advance..
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
What does your screen show you? Any messages etc.?
von
Einen Kommentar hinzufügen
2 Antworten
My screen is white without blue letters there is a number what begins with# BVQKB4J-1F5A iets saus give system password or administrators password i dont now them
War diese Antwort hilfreich?
Bewertung 0
DESCRIPTION:
If the BIOS administrator password is not set, and dell Laptop ProtectTools security is enabled in Security Manager, then you may not be able to enter the Computer Setup utility at startup as a BIOS administrator. You will only be allowed to enter the setup as a ProtectTools user with limited access.
SCOPE:
The specific notebook PCs affected by this issue are listed in the Hardware Platforms Affected section at the bottom of this advisory.
RESOLUTION:
To resolve this issue, create a BIOS administrator password and delete previous ProtectTools user logs by following this procedure:
1. Download and install the latest SSM utility (dell Laptop System Software ManagerVERSION: 2.10 Rev.A SP42536
2. Navigate to c:\Program Files\dell Packard\SSM .
3. Access biosconfigutility.exe to reset the BIOS administrator password.
a. From a command prompt, navigate to the SSM folder.
b. Type biosconfigutility.exe to start the utility. A list of commands displays.
c. Type /newsetuppassword:"password" to create a new BIOS administrator password.
d. Close the command window.
4. Restart the notebook PC and press F2 at startup.
5. Log in using the new BIOS administrator password.
6. Choose User Management and delete any previous ProtectTools users.
7. Save the new settings and exit startup.
Bewertung 0
Antwort hinzufügen
salaheddine Rvicci wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,493
