Alcatel Pixi 3, and some other similar/related phones
-- There is a common fault with the charging docks. Although the dock is supposed to be superior to the USB/charging plug, these phones have poor quality docks. The idea is, after repeated use the weaker component will fail first. In many cases the weaker componant is unfortunately not a cheap cable that nobody would mind replacing.
-- there are also 2 other very common issues. One is with the ribbon feed wires from the battery to board. It's not uncommon for the small plug to work loose, (through phone movement/vibration, heating, etc), creating a poor enough connection you can experience a number of issues, most commonly:
Without warning the phone may simply power off and fail start. If left for a while it may fully start and last a few hours, or it may power off just half way through the first boot. Typically, if it doesn't last through the boot-up this time then it won't make it much further than the first vibrate next time round.
++ To solve this, remove all the tiny screws and remove the battery. Inspect the connections and manipulate the connection rods very slightly in such a way to create a more rigid hold once the plug is returned. A drop of an epoxy, or non-conductive super glue on top of the fixing should prevent this repeating.
-- Another problem, a little less common yet with similar symptoms is again a circuitry connection issue. By t
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
39 Kommentare
Yeah, I came to this website to find out how much it costs to get my phone fixed because i had this same problem. Accept for the fact that with my charger, there were a few of the things that were inside that connected the charger and the phone together so therefore it could charge, a few of those were missing.
von Lupe Runnels
just try to upgrade it using one touch upgrade s 2.8.0
von kifuhowe
I got my phone yesterday and it stoped working I charged it and took the battery out and put the battery in and it wouldn't work
von Kydyn Gaitan
Same though my phone was not in the charger, it was on 48% , but when i woke up it didnt want to turn on i tried putting it in the charger, i tried putting a pin in that hole and still wouldnt work.
von Ruqayah
I have two problems with mine. I put it on the charger and I have to bend the charger to the side so it will charge. and my phone keep freezing and shutting off. but when it it freezes i take out the battery and out it back and its fine. but it does this at least 3 times a day. I don't know what is wrong with it. or how to fix it.
von Jay Hope
34 weitere Kommentare anzeigen
