Zum Hauptinhalt wechseln
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
98 Neon cranks over no sparks
Replaced the water pump and some other parts and now it doesn't start but crank over but no spark
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Things to Check- Spark plugs, plug wires, coil(s), and crank angle sensor. Here is a good youtube video that will help you diagnose the problem although year and coils are not exactly the same as yours and you probably don't have the testing equipment they do it gives you some good info on what to look for.
https://www.youtube.com/watch?v=xwh3XM1N...
Also just double check all your plugs and grounds to make sure they are in tight and secure and that you did not get any water in them when changing the water pump.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
normagroth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 242
