Zum Hauptinhalt wechseln
Der Nintendo DS Lite kam 2006 als Nachfolger des Nintendo DS auf den Markt. Er ist leicht zu öffnen und leicht zu reparieren.
316 Fragen Alle anzeigen
Just Replaced Hinges, Now Upper Screen Shuts Off
After putting my DS lite back together (replacing hinges) I now have upper screen problems. It comes on, them immediately goes black. The lower screen works fine. I re-worked it, same problem. Should I try a third time? Please don't tell me somehow I blew my upper screen.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The main thing that people do by mistake when fitting a new hinge is inadvertently tear the top screen ribbon. This will make the tops screen flash as if its going to come on and then go black - Your DS power light will also flash as this issue will prevent your DS from booting. Things to check - make sure the top screen ribbon is fully inserted into the connector, I know it sounds simple but its an error that lots of people make. If this doesnt work and you cant see a tear in the ribbon either, I'm afraid its a new top screen. Although obviously it'd be a new top screen if the cable has a tear in it.
Regards
Justin Bayliss
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Good answer.
von
Thanks, I'll give it another look. I really don't think I tore the ribbon. I was very careful and also the bottom screen works fine. It's very tedious work and I have been letting this sit for months. If this it's not a bad connection I may scrap it before I buy another screen...this has been more than I care to deal with. My poor daughter is terribly attached to her DS lite. She will not like the idea of just buying a new one. Thanks again!
von
Antwort hinzufügen
queekyquilter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 4,318
