rockwheel gr16-20r and gr16-25r
how to distinguish between rockwheel gr16-20r with rockwheel gr16-20r is there any a special code?
Ist dies eine gute Frage?
RockWheel is the dangerous wheel or not ?
War diese Antwort hilfreich?
There are two types of “RockWheels” you could be referring to: 1) a heavy equipment used to cut rocks, and 2) an electric unicycle made in China. I have 2 of the latter ones and whose batteries have stopped working. I am looking for replacement batteries, hopefully upgraded.
I have not tried to take the old batteries out yet.
Any info you have sent my way would be appreciated.
FYI: Both are dangerous, but the former much more than the latter. :-)
I would say you need to check the battery specs. inside the Rockwheel. I believe the battery inside is the only difference.
The GR16-25R has a battery that the Mfg. refers in its specs. as “296Wh/ 32pcs”, whereas the GR16-20R has a little less battery-life and is referred to as “236.8Wh/ 32pcs.”
Hope this helps. I am looking for a replacement battery currently. tyanceyATemtrainDOTcom
Ty
On 2018-09-15ish
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 610
