Zum Hauptinhalt wechseln
Vierte iPad-Generation, erstmals erhältlich am 2. November 2012 in Wi-Fi, CDMA und GSM Versionen mit 16, 32 oder 64 GB Speicher.
408 Fragen Alle anzeigen
Dropped iPad and screen is black
The iPad dropped from my knee only a short distance onto my foot, but the screen is completely black and won't turn on. I tried connecting it to the charger and it made the 'ping' sounds, so is not completely dead. I've tried tapping it on the back but it didn't work. Is there anything I try before I send it away?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Don't tap it, whack it! Watch video below for demonstration.
Black Screen of Death Fix
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for your assistance. Unfortunately, it was a broken backlight, but found Gadget Van (Cheshire) who repaired it straightaway for less than half the price Apple charge.
von
Hilfreichste Antwort
give it a good smack on the back side, right of the apple logo. its were the connector is inside.
Bewertung 1
1 Kommentar:
Thanks anyway for your response.
von
I would check if the lcd connector needs reseated or if the lcd broke.
But first try holding the home and power buttons for about 10-15 seconds then try turning it on.
worst case is you broke the LCD which is not bad
Bewertung 1
1 Kommentar:
Thanks for your response. It was a broken backlight.
von
If the percussive maintenance doesn't work you will have to open up the iPad and reseat the lcd cable. You will need to power off the iPad before opening it up. Just hold the power button for 6 seconds then swipe approximately where the swipe to power off option would be.
Bewertung 1
1 Kommentar:
Problem was a broken backlight, but thanks for responding.
von
Antwort hinzufügen
Bonsie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 86
Insgesamt: 6,414
