Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Bluetooth problem after screen replacement
Hi everyone,
I changed my screen, there were no problems, but during reassembly I changed the screws fixing the cap for the screen connectors.
I changed the lower left with the lower right, and on the lower left side I felt a resistance while screwing.
I then realized my mistake and changed the screws into their correct order.
Since then I cannot make phonecalls in my car.
I can listen to music via Bluetooth, I can control the iPhone via car's controls, even the cars microphone does work, but cannot hear the audio from the phonecall.
Do you have any ideas what could have happened
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Lower left and right screws are the same, this is not screw related.
War diese Antwort hilfreich?
Bewertung 1
Any chance you ever resolved this issue? I have the EXACT same problem and replaced my screen as well.
Bewertung 0
1 Kommentar:
Since I experienced this issue a few hours ago, I have no solution.
I guess that the digitizer is broken.
von
Antwort hinzufügen
mathiasparyla wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,093
