Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Battery drain even after replacement.
So I`ve changed my old battery to iFixit battery, but battery still drains like 1% per min when using. So I`ve heard about U2 chip, but my phone charges normal and when i`m drained battery empty i can charge it. I`ve minimalized usage as possible, but nothing changes.
Ist dies eine gute Frage?
Bewertung -1
6 Kommentare
guys? its u2 or what?
von
before replace the battery is there any fault? did your previous battery had same fault?
von
previous battery had 527 cycles and power iBackupbot showed 700MAh from 1420MAh so i that needed replacement. Phone have not been any water damage or so. Always charged with apple charger who came in package.
von
I tried reseting settings, reseting all software, even downloaded iOS 8.4, no changes.
von
so what is it then?:(
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
1) Before touching U2 check below steps
  • Turn off all connectives such as Wi-Fi, BT, Mobile data and check whether any improvement of battery life
  • Again restore via iTunes and setup as new device ( check the device before restore the all contents of your iCloud and apps)
  • if above steps not worked for you,
1) Remove insisting battery
2) cut off Old battery contact wire with doc connector
3) Connect Voltage(V) and power(A) analyzable power supply (make sure + and - correct)
4) Tune voltage to 4.0V
5) Turn on the phone pressing power key and measure taking current (mA) and it should be around 5mA to 1140mA if power taking beyond 1500mA your logic board having some kind of short circuit.
let me know the result. there is few steps to check in logic board
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
Tried first steps, no results, same thing.
Where do I get analyzable power supply? Can I buy it? I don`t think I have one.
Thank you.
von
And one more thing, phone standby can sit like 3 days if I`m not using it, when I start using rapid battery drain, also I can listen to music, battery works fine with no drains, as soon i unlock it and start even texting drains start, phone is cool and not hot.
von
Maybe I should dissamble it and put back together? That would change anything?
von
its a variable power supply
von
Hello alexjakob,
you no need to worried about your motherboard or other components. as you said battery drain without hot.(According to basic physics theories :-) ) fault coming from your battery. if you have battery analyzer you can check the capacity of battery otherwise replace it
von
Check the dock connector, could be some debris causing a short.
Bewertung 0
2 Kommentare:
how do i clean dock connector??
von
Power the phone off and use some rubbing alcohol (99%) and compressed air.
von
Have you tried factory restore? My guess is that it is not hardware but software issue
Bewertung 0
1 Kommentar:
Did factory restore and started as new iPhone, still rapid drain while using.
von
Antwort hinzufügen
alexjakob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 216
