Washer will not drain after wash cycle?
Tried Spin cycle several times.
Ist dies eine gute Frage?
Ken, if it sits there waiting to drain, check to see if it is absolutely silent or if you can hear a hum. If it hums it could be something stuck in the drain pump or you may have a defective drain pump. Check on here how to replace the pump. If it does not hum then the problem is more likely the lid switch.
War diese Antwort hilfreich?
Good answer!
You saved my day!
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 2,386
