Zum Hauptinhalt wechseln
Repair guides and support for tablets manufactured by Insignia, a Best Buy brand.
tablet will not turn on
it not comeing on and yes it is fully charged
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 11
5 Kommentare
I purchased 3 tablets for my chandchilden. They will not charge at all. The screen remains black
von
I Lt doesn't turn on or anything I've been charging for 3 days know and nothing
von
My Tablet will not even turn on and the screen is still black, What should i do?
von
My tablet will not charge while in the charger. It will decrease the charge instead of the other way around so I'm not sure what I should do about it and it's like 6% I think right now not sure if I need a new battery or if there's a way to fix it I just wanted to let you know I asked you what I should do let me know?
von
i don't want to reset my tablet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If all else fails you can try a hard reset which will wipe all your data and start you from new. This is done by pressing the start button and the up volume button at the same time . Hold them both down till the machine starts . you will see probably the android and then a selection menu . Use your volume to scroll up and down the menu . Select factory reset and then yes wipe data and it will reformat the tablet and it will start from new. Hope this helps.
War diese Antwort hilfreich?
Bewertung 8
8 Kommentare:
how do you remove the battery?
von
This one requires soldering to remove but if your hand with an iron this will help
Insignia Flex 10.1 NS-P10A6100 Battery Replacement
von
It doesn't turn on should we charger it or what??
von
Or how long to take to turn on
von
It will not charge!?
von
3 weitere Kommentare anzeigen
Try removing the battery. With the battery out hold the power button down for 60 seconds. But the battery back in and try turning it back on. If the light comes on the LCD screen could be ruined. Might have to change that. But doing the first step i said fixes quite a few issues.
Bewertung 3
6 Kommentare:
How to remove it
von
Yeah how do u remove it
von
Wow Tyler Black thanks so much this helped it totally worked i tried taking battery out but would come out but just took the back of the tablet off and did what you said and it came right on thanks
von
my tablet is fully charged but not starting
von
my iPad is not working because it has a little crack in the back and I'm clicking the power button for 60 seconds and then not working
von
1 weiteren Kommentar anzeigen
Check the place where you plug in the charger. Sometimes the prong inside gets a tiny bent. Wiggle it a bit with some tweezers and you should be good to go. I used to refurbish tablets and it happens with all brands. This may also work on your phone if you ever have the same problem.
Bewertung 2
2 Kommentare:
It is very annoying to reset your device and lose everything so try this first! Also to clean it a lightly damp q tip of alcohol will do the trick
von
How can you reset it if the screen does not open. It is pretty hard to reset when the screen is black.
von
Antwort hinzufügen
jloza84 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 47,122
