Zum Hauptinhalt wechseln
Ein e-Book-Reader von Amazon. Er ist leicht zu reparieren, es werden nur Hebelwerkzeuge und Schraubendreher benötigt.
55 Fragen Alle anzeigen
Kindle Paperwhite Repair code comes on after screen replacement
Can anyone help me with a problem. I replaced my kindle paperwhite screen and now I get the screen saying repair needed. Battery invalid:-22. I am glad the screen works.....
Help??
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Did you find any solution to this?
I have exactly the same problem. I assembled a paperwhite 2nd-gen screen with a paperwhite 1st-gen motherboard and get exactly the same error.
EDIT (typing mistake): it was a 2nd-gen motherboard and a 1st-gen screen
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Where did you find a screen of 2nd gen? I need to replace mine.
von
Oh sorry... I mistyped something. What I meant was i assembled a "paperwhite 1st-gen screen and a paperwhite 2nd-gen motherboard"
von
Received a 2nd-gen screen today, still getting repair-message.
Bewertung 0
5 Kommentare:
It's not good. Last week I bought this one http://www.ebay.com/itm/311350255136 (2nd gen screen to my 2nd gen motherboard) and I'm waiting to receive it. I hope not to get the same message because I don't know how to deal with it.
von
The message is "Battery invalid:-22.", correct? Did you try to disassemble and connect the battery again? Or a hard reset?
von
That's correct! Yes, I tried both. My current approach is to try it via serial connection. Maybe it's just a software-issue that could be fixed that way. Has your screen arrived yet?
von
Hello, men! So, what with your Kindle now? A you repair it? I have a same problem now.
von
von
Any solutions? I have same problem
Bewertung 0
I came across a russian site http://kindle.zzweb.ru/paperwhite/repair.... Basicly it sates this:
  1. Connect the Kindle Paperwhite to a computer USB-cable.
  2. Create an empty file in the root directory DO_FACTORY_RESTORE.
  3. Safely disconnect the reader from your computer.
  4. Reboot your device by holding the power button.
I did this and my kindle paperwhite did a factory reset and I was able to use it again. I had previously tried to format the drive and place a firmware update on the drive so I do not know if this will remove your books. Please try and back up your books if you can before you do this.
Hope this helps others.
Bewertung 0
Antwort hinzufügen
sdinovitz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 2,429
