Zum Hauptinhalt wechseln
Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
15 Fragen Alle anzeigen
Removal of rear cover?
Hi there. I have a Samsung Chromebook 2 (XE503C12) and want to remove the rear cover. I don't see ANY teardowns or even videos on YouTube about this. Does anyone know how to do it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Steps to remove the bottom plate from the device.
The bottom plate consist of 9x 4mm screws. Remove these first. There are no hidden screws under the rubber feet.
Using a spudger, insert it in between the bottom plate and the palmrest assembly. Gently rotate the spudger to loosen the clips holding the bottom plate into place around the perimeter of the device. Once you go around the entire outside of the bottom plate the plate should lift free.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you VERY much!!! This was awesome!
von
Antwort hinzufügen
Kelley Chambers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 518
