Zum Hauptinhalt wechseln
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Problem with my EEPC
I formatted part of a key USB my hard drive C: with Gparted. so I deleted lartition hidden.
I does not happen again to install Windows XP from a USB key because it tells me that it can not find C: drive on my EEPC.
Thank you for your solutions
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
So you deleted your hidden recovery partition? Then you cannot use the recovery option in the BIOS anymore.
"C:" is not a physical drive, it is the name ("drive letter") of a file system of a partition on a drive. A proper operating system installer should first give you the option on which physical drive to install. Then you may even create a partition of your preferred size. This will get formatted and named "C" as default. Then the installation starts.
I don't know what's on your USB key, but maybe you need to prepare it newly from a proper CD image. You may also connect a disc drive via USB and install from a disc directly.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Didier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 437
