Zum Hauptinhalt wechseln
The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
65 Fragen Alle anzeigen
Right side heaphone jack not working
The desire 816's jack doesn't seem super solid in the first place. However, my 816 fell on a hard floor and now when I plug in any headphones to the jack, the right side earphone doesn't work. This seems like an internal issue in the phone. Wonder if you all have any solution! Thanks!
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
i have this too
von
Connect the headphones to another device and check if they work properly. They probably won't because if the headphones Jack would have been not working then neither of them would have been working.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
You may have to replace head phone connector
War diese Antwort hilfreich?
Bewertung 1
It looks like your head phone jack is failing. The head phone jack consists of spring loaded contacts and due to the impact it may have been bent out of place. It may be possible to bend the contact spring back to place however, if this does not work the only solution would be to replace the headphone jack completely.
Bewertung 0
First of all you need to go to the htc service center and ask them to change the earphone jack.
Bewertung 0
Antwort hinzufügen
Ryam Green wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 342
