Zum Hauptinhalt wechseln
Harley-Davidson Sportster-Motorräder von 1986 bis heute.
Why does my oil light come on when the motor gets warm?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
You might want to make sure you are using a straight 30w, or heavier, oil and that the oil is not broken down by heat or contaminated by gas/solvent. If it is not the oil itself, then it could be the sensor (hopefully) or some bearing is getting loose enough to impact the oil pressure when everything's warmed up.
von Teilen
If you are using 20/50 and your oil level is within spec after it has been warmed up then you have an oil pressure issue. For a quick test, with the bike running, look into the oil tank. Do you see air bubbles and the oil moving? Another quick test: Place a pan under the oil filter > remove oil filter > start bike (it'll take 10 sec of run time). Do you see any oil being pumped out from the feed line into where the filter would be?
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Noah is right.
Another possibility is degraded oil and more probable, a worn oil pump.
( a tooth wheel pump )
Change the oil and look carefully for metal-chips.
Check ( by taking it to pieces ) your oil pump then!
Good luck !
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 4,108
