How to Fix no Power
How to Fix no Power...i dont know how to fix this...
Ist dies eine gute Frage?
Check the wires and contact of the batteries. If all are good. Check polarity of batteries. If all is good. A tiny line of the circuit board is burnt because you put the batteries in a wrong way And there is no fuse.
War diese Antwort hilfreich?
If there is burnt bit in the circuit board and no fuse what can I do to fix this problem?
To fix the burn in the circuit board you have to have a soldering gun, flux paste, tin- lead and good soldering skills. To repair , first you have to find the area that has the open circuit, then remove the green material that protects the cooper for corrosion. Put a bit of flux paste on the expossed part of the circuit that we previously peel. Then solder the area putting a bit of tin-lead. Find a piece of wire (small caliber..18-24 gauge)to make a bridge in the 2 areas.
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 1,784
It looks like I have some corrosion in one of the battery chambers of my camera, is there and way of sorting this and repairing??
von becky donald
