Zum Hauptinhalt wechseln
Information and repair guide for the Samsung RF220N*TA** refrigerator—a 2014 bottom-mounted freezer model with French door access and compact design, suitable for built-in usage in limited spaces. This page covers information for model numbers matching the pattern RF220N*TA**.
3 Fragen Alle anzeigen
Why are my fridge and freezer not cold enough?
We noticed about two weeks ago that our 3 yr old Samsung Fridge, model rf220nctasr, is not cold enough (both fridge and freezer). Since then, we replaced the evaporator fan and cleaned the condensor coils. No change.
Other observations:
- The condensor fan seems to function adequately. It does sometimes run even if the compressor doesn't (we noticed that once).
- The compressor is really hot to the touch.
- The evaporator fan runs and pushed cold air when the light in the freezer isn't on. Can't confirm if it stops working however.
- The evaporator coils are not evenly frosted.
- We do not hear any clicking noise.
- Self diagnostic returns no error.
Repair person seems to think we should replace the freezer evaporator and filter dryer, but from my research, if the evaporator was defective, there would be an ice build up ?
Thank you!!!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The key symptom is the hot compressor. My first thought would be low refrigerant level and this requires a licensed technician.
Here's how to check it out:
https://fridgeman.wordpress.com/2008/06/...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
sindyhoule wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 3,445
